It is currently Mon Aug 18, 2025 4:51 am
Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
PostPosted: Mon Aug 04, 2014 11:28 am
I can understand that - taking your time is often a good thing to do when attempting a new repair. While you are waiting you could glue up a test piece or two with fish glue and test one or more of the methods that have been discussed here. Good luck with it.
PostPosted: Wed Aug 06, 2014 2:31 pm
Steve said.. " While you are waiting you could glue up a test piece or two with fish glue and test one or more of the methods that have been discussed here"
I have glued up a couple pieces of maple about 1/4 inch thick. Have let it set/cure for two days. Tomorrow I will try to separate the two pieces using heat only. ( i.e. clothes iron.)
Under Compensated Nut!
PostPosted: Wed Aug 06, 2014 3:09 pm
Give them a bit more time than that, another 2 or 3 days. You really need to make sure that all the residual moisture from the glue has gone.
